What is Banana Pi M64-R18?
Banana Pi BPI-M64-R18 is a 64-bit quad-core mini single board computer. It features 2GB of RAM ,8GB eMMC,onboard WiFi and BT. On the ports side, the BPI-M64-R18 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port.
  • 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
  • 2GB DDR3 SDRAM with 733MHz.
  • 8 GB eMMC storage (16,32,64 options available).
M64-R18 Specifications
CPU 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor
GPU MALI-400 MP2 @ 500MHz
Memory 2GB DDR3 SDRAM (shared with GPU)
Storage Support MicroSD Card(up to 64GB)/eMMC(8GB onboard)
Onboard Network 10/100/1000Mbps ethernet (Realtek RTL8211E/D)
WiFi 802.11 b/g/n (AP6212)
Bluetooth BT4.0 (AP6212)
Video In CSI connector that supports 8-bit YUV422 CMOS sensor CSI, CCIR656 protocol for NTSC and PAL, 5MP camera, 1080p video @30Hz
Video Out HDMI 1.4 with resolutions (upto 4K @24Hz)
MIPI DSI for RAW LCD panels
Audio Out 3.5 mm Jack and HDMI
Audio In On board microphone
Power Source 5V 2A DC port
USB Ports 2x USB 2.0, USB OTG(Micro USB)
GPIO 40 Pins: GPIO, UART, I2C bus, I2S bus, SPI bus, PWN, +3.3v, +5v, ground
LED Power status Led and RJ45 Led
IR Onboard IR receiver
OS Android and Linux etc.OS
Dimensions 92mm x 60mm
Weight 45g
M64-R18 Interface
Shares the same interfaces with M64
M64-R18 GPIO
translate
